ASA 8.x - threat-detection: show threat-detection rate access-list
May 13th, 2008
  • Bronze, 100 points or more
Hi folks.
I'm tinkering around with threat-detection and in the docs (http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/protect.html)
it states:
To view the top 10 ACEs that match packets, including both permit and deny ACEs., use the access-list keyword. Permitted and denied traffic are not differentiated in this display. If you enable basic threat detection using the threat-detection basic-threat command, you can track access list denies using the show threat-detection rate access-list command.
However that command isn't even an option :
ASA# show threat-detection rate ?
acl-drop Enter this keyword to display access-list drop statistics
bad-packet-drop Enter this keyword to display key bad packet drop
statistics
conn-limit-drop Enter this keyword to display connection limit related drop
statistics
dos-attack-drop Enter this keyword to display key DoS attack drop
statistics
fw-drop Enter this keyword to display general firewall drop
statistics
icmp-drop Enter this keyword to display all icmp-related drop
statistics
inspect-drop Enter this keyword to display all inspection drop
statistics
interface-drop Enter this keyword to display key interface drop statistics
min-display-rate Enter this keyword to display rate statistics whose average
rate exceeds the min-display-rate.
scanning-threat Enter this keyword to display key scanning drop statistics
syn-attack Enter this keyword to display TCP SYN attack and no data
UDP session attack statistics
show threat-detection rate acl-drop
Average(eps) Current(eps) Trigger Total events
10-min ACL drop: 3 0 0 1982
1-hour ACL drop: 1 0 0 3737
I can get the ACL hits with show threat-detection statistics top access-list, but I'm interested in the ACE's:
ASA# show threat-detection sta top access-list
Top Name Id Average(eps) Current(eps) Trigger Total events
1-hour ACL hits:
01 inside_access_out/3.5 1 0 0 5214
02 inside_access_out/6.2 0 0 0 678
03 inside_access_out/3.6 0 0 0 95
04 inside_access_out/3.1 0 0 0 5
8-hour ACL hits:
01 inside_access_out/3.5 0 1 0 11060
02 inside_access_out/6.2 0 0 0 1862
03 inside_access_out/3.6 0 0 0 449
04 inside_access_out/3.1 0 0 0 9
05 inside_access_out/3.7 0 0 0 2
24-hour ACL hits:
01 inside_access_out/3.5 0 2 0 11060
