7960 old old SIP firmware, how can switch to Skinny?
May 13th, 2008
I cant figure out for the life how to get the old SIP firmware off the 7960/7940 phones and switch to Skinny. I tried 79XX.TXT file and it gets me no where. Anyone have a shortcut way to make this work?
Thanks!
Tommer Catlin Tue, 05/13/2008 - 12:38
I tried the factory reset with holding down the button and waiting for the blinking headset, hold, etc and couldnt get it to work
Paolo Bevilacqua Tue, 05/13/2008 - 12:43
You need to caputure the tftp messages, use a router or tftpd32.exe for that. Usually the reason is that phone is looking for some file and not give. Also, you can try loading first, an old sccp image, like 5.x
Tommer Catlin Wed, 05/14/2008 - 07:07
yeah, on the phone status we could see which file it wanted and in the log. Even though we put the file in the TFTP dir, it still would not take it.
Paolo Bevilacqua Wed, 05/14/2008 - 07:21
Are you using tftp32d or what? If the phone request the file and is there, it must be given.
Tommer Catlin Wed, 05/14/2008 - 07:23
Tried TFTP32 and the CUCM server. couldnt get it to work. It's the original SIP 3x load
