Codec payload change
May 13th, 2008
My customer is having an IP link to make international VoIP calls. The codec used in these trunk is G.729. But the problem is that the other end gateway will accept G.729 calls only with a payload of 30. By default the payload size for G.729 in Call Manager is 20, and this is the same used for their other internal VoIP calls.
If you want to change the payload, as far as I Know it has to be done under the Service parameters and will affect globally.
Because of this issue, we are not able to proceed with our integration. So please let me know if there is any way to change the payload type to 30 only for this particular trunk.
Manu
gogasca Wed, 05/14/2008 - 16:28
  • Green, 3000 points or more
Do we have any MTP in the middle?
Or call is just IP Phone --- RTP --- Remote peer ? We can try MTP
No way to change the payload for an specific H323 call or SIP
manumohan200 Tue, 05/20/2008 - 08:47
Right now there is no MTP. But to acheive this requirement, we can put MTP in between. Please tell me how I can acheive my requirement using MTP.
Manu
gogasca Tue, 05/20/2008 - 17:27
Im thinking in configuring packet size in MTP profile and test.
Or we can try using an IP IP GW in the middle
manumohan200 Tue, 05/20/2008 - 20:24
I checked for configuring the payload size under MTP profile, but it's not there.
Can you tell me how to do the same?
Manu
