Start-up-config ?
May 13th, 2008
Is there a way to make a change to the start-up config and not the running
Config on a 3560
I need to make changes ONLY on the interconnect ports and this needs to be done remotely
I would like to make the changes and set the reboot times
I know if I tftp the file I need the whole config.
I like to do this with partial config if possible
Richard Burts Tue, 05/13/2008 - 13:59
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
James
The only way that I know of to change the startup config (other than copy running startup) is to tftp to the startup. And you are correct that tftp to startup requires the complete config. I do not know of any way to selectively change part of the startup config - and I believe that no way exists to selectively change part of the startup config.
So I believe that you only option is to get a copy of the complete startup config, change the elements that you need, and tftp the entire changed config to startup.
Rick
jfeo Tue, 05/13/2008 - 15:03
Thanks Rick
if anybody else knows a way to do this please let me know thanks
