default gateway command
May 13th, 2008
I am just trying to learn about cisco routers and i came across th ip default-gateway command used at the global configuration mode
What is that command used for
I know on pcs we set the default gateway address for the router
please inform me
Overall Rating: 4.7 (3 ratings)
bvsnarayana03 Tue, 05/13/2008 - 23:11
Its very much similar to the default-gateway on pc. Infact this command is used on network devices which doesnt support routing or if routing is disabled. Mostly L2 switches have this command pointing to the router which wil then route the traffic to required destinations.
mahesh18 Sun, 05/18/2008 - 13:45
hi
i have switch 3560
when i do sh ip route it shows
sh ip route
Default gateway is 182.22.77.254
Host Gateway Last Use Total Uses Interface
ICMP redirect cache is empty
but this is layer 3 switch??????????
Jon Marshall Sun, 05/18/2008 - 13:48
Mahesh
You need to enable "ip routing" on the switch. See other thread.
If you do not enable ip routing then the 3560 will just be a L2 switch and it will need a default-gateway.
If you enable ip routing then it can now be a L3 switch and you would replace your default-gateway with a default route.
Jon
mahesh18 Sun, 05/18/2008 - 13:51
hi jon
so on thAT 3560 SWITCH i have no ip routing
configured thats why i had default gateway
right?
joseph.derrick Wed, 05/28/2008 - 21:32
Hi Mamesh,
The command "ip default-gateway" is used if routing is disabled on a device. For example, this is used for managing the device remotely. Since it has a default-gateway just like computers, this simply mean that it can communicate in the network.
On the other hand, if routing is enable, you don't need the command "ip default-gateway". You can use the command "ip route x.x.x.x y.y.y.y" instead to let your device communicate with other devices on the network.
Deejay
