log synchronous command
May 13th, 2008
HI
i just wanted to know what is this command used for at console or vty line
"timeout login response 4"
and the second command
"log synchronous "
plase help
Gursaran Abott
Hi Gursaran
See this Cisco document http://www.cisco.com/application/pdf/paws/13370/tacacs_login.pdf regarding the command "timeout login response 4"
The command "logging synchronous" is a useful when you are receiving console messages while you are entering EXEC or privilege level commands. Without "logging synchronous" enables the test of the commands you are typing gets lost in the console message. However when "logging synchronous" is enabled, then the command you were typing will be displayed on a new line after the console messages is displayed. I makes configuration a whole lot easier, so I would normally configure "logging synchronous" on the console and VTY lines on all my routers & switches.
Best Regards,
Michael
