Caller ID Name
May 13th, 2008
Until recently I was running Call Manager 6 with an MGCP gateway. I converted the MGCP gateway to H323 but now I am no longer getting Caller ID name from the PSTN (PRI). I am only getting the numbers. Does anyone know how to configure an H323 gateway to support CID Names?
izackvail Tue, 05/13/2008 - 15:47
Thanks anyway but I just found it!
At the voice service level:
voice service voip
h225 display-ie ccm-compatible
At the voice class level:
voice class h323 1
h225 display-ie ccm-compatible [system]
To enable the H.323 Display feature with buffering for ISDN trunks that use the Facility message to deliver Name Display information, additionally configure the following:
interface Serial0/3/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
isdn map address *. plan isdn type unknown
isdn supp-service name calling
isdn bind-l3 ccm-manager
no cdp enable
christfoster Mon, 08/04/2008 - 08:19
What yIn the h323 protocol the call manager can't understand the calling name
in the Facility IE. The PSTN/PBX has to send us the calling name in the
Display IE. These are the two fields which comes in an isdn q931 setup
message. The CM can understand the calling name in Facility IE if we are
running MGCP protocol.
In order to get the caller name displayed on the IP Phone we need to get
the caller name in the display ie field of the Isdn q931 call setup
message. This can only be configured on the Telco/Wind stream. switch. You will have
to ask your telephone company/service provider to enable sending of
display ie in the call setup message."
config the information below::
Interface Serial3/0:23
isdn outgoing ie facility
no isdn outgoing display-ie
