Loading new PIX 515E startup config...Easy question
May 13th, 2008
I can not seem to get this right. Im trying to load a new PIX configuration file to the startup config of a PIX515E so when a reboot is done, it loads the new config. This is for a ISP change at a live site. I guess TFTP would work and i could verify config after but i can not even get that far. Can someone please provide the correct syntax for a PIX 515E 6.3(4).
Thanks in advance,
Robert
Overall Rating: 5 (1 ratings)
JORGE RODRIGUEZ Tue, 05/13/2008 - 21:35
  • Green, 3000 points or more
Here you go.
Backing up and restoring in your version code
say this is the tftp server ip: 10.10.10.1
pix515cfg is just a make up name, you may use different name.
backing up config
Firewall#write net 10.10.10.1:pix515cfg
restoring or pooling config from a tftp server
firewall(config)#config net 10.10.10.1:pix515cfg
-Jorge
rthreshier Wed, 05/14/2008 - 07:38
I need to copy configuration to the startup config only.
JORGE RODRIGUEZ Wed, 05/14/2008 - 10:41
As far as I know in PIX code 6.x there is no concept of running or startup config like you would find in IOS based devices, unless you are running code 7.x or above you can do it. So you could either build your config on an exact diffrent model and push it to others same models via tftp and reload.
Pix code 6.3.5 or bellow
PIX515E# show flash
flash file system: version:3 magic:0x12345679
file 0: origin: 0 length:1978424
file 1: origin: 2097152 length:82185
file 2: origin: 2621440 length:3557
file 3: origin: 2752512 length:3152452
file 4: origin: 0 length:0
file 5: origin:16646144 length:308
PIX515E#copy tftp ?
Usage: copy capture: tftp:/// [pcap]
copy http[s]://[:@][:]/
flash[:[image | pdm]]
copy tftp[:] flash[:[image | pdm]]
PIX/ASA code 7.x or above
asa5500fw# copy tftp startup-config
Address or name of remote host []?
-Jorge
