May 14th, 2008
Can you provide the sample commands based on following requirements?
1. 10 mbps Ethernet link towards customer.
2. I need to allocate 2 mbps vpn link for customer on PE interface
3. Inside the 2 mbps I need to define the QoS for various applications. Like EF 1.5 mbps AF2 -200 kbps …
Overall Rating: 4.5 (2 ratings)
mheusing Wed, 05/14/2008 - 01:46
a hierarchical policy will allow you to achieve your results assuming you have defined the class-maps properly:
policy-map CBWFQ
class EF
priority 1500
class AF2
bandwidth 200
class class-default
policy-map Shape2mbps
class class-default
shape average 2000000
service-policy output CBWFQ
interface Ethernet0/0
service-policy output Shape2mbps
Please note, not every IOS and platform does support hierarchical policies. You need to check with the Feature Navigator, what is available in your particular case.
Hope this helps! Pease use the rating system.
Regards, Martin
