CDP Issue(
May 14th, 2008
Dear ALL
If i am using CDP on my Routers iam not able to discover any CDP neighbours and
if i am using CDP on switches i am able to discover all LAN Devices
Could some body help me
Out put of CDP on my ROUTERS is below,
#sh cdp
Global CDP information:
Sending CDP packets every 60 seconds
Sending a holdtime value of 180 seconds
Sending CDPv2 advertisements is enabled
sh cdp traffic
CDP counters :
Total packets output: 789061, Input: 0
Hdr syntax: 0, Chksum error: 0, Encaps failed: 0
No memory: 0, Invalid packet: 0, Fragmented: 0
CDP version 1 advertisements output: 0, Input: 0
CDP version 2 advertisements output: 789061, Input: 0
sh cdp
sh cdp interface
Ethernet0/0 is up, line protocol is up
Encapsulation ARPA
Holdtime is 180 seconds
######sh cdp ne
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater
Device ID Local Intrfce Holdtme Capability Platform Port ID
mahmoodmkl Wed, 05/14/2008 - 00:39
  • Gold, 750 points or more
Can u verify it the other end is enabled for CDP.
Mahmood
UCBNOCWAN Wed, 05/14/2008 - 00:57
Other end it is enabled
from all the switches i am able to see the neghbours excpet the router.
mvandorp Wed, 05/14/2008 - 01:19
What is your interface configuration? Is an ACL blocking things?
Marcel
UCBNOCWAN Wed, 05/14/2008 - 18:13
There is ACL on ethernet interface (LAN)
Extended IP access list 141
10 deny tcp any any eq 1639 (30717 matches)
20 permit ip any any (1326742325 matches)
My ethernet config is below
interface Ethernet0/0
description ### LAN ###
ip address ##########
ip access-group 141 in
ip route-cache flow
half-duplex
standby ip ##########
standby preempt
how to configure IP CDP
Please advice on the same.
Edison Ortiz Wed, 05/14/2008 - 20:12
  • Hall of Fame,
    Founding Member
CDP is enabled by default and no need to configure it. Your original post confirms CDP is running on that interface.
Can you post the portion of the config from the switchport connected to this router?
You may be experiencing a duplex mismatch issue which is affecting CDP. I noticed your Ethernet interface is running half-duplex, you must match this duplex setting on the switchport as well.
__
Edison.
sanjay.khurana Wed, 05/14/2008 - 06:24
U need to configure IP cdp on interface also.
and after that u can check the cdp status..
bmcginn Wed, 05/14/2008 - 20:09
  • Bronze, 100 points or more
use "cdp run" in global configuration on both devices, or if you don't want CDP on a particular interface, you can disable it on the interface using "no cdp enable"
cyptic Fri, 05/16/2008 - 04:28
Hi!
We need so see your complete interface configuration both for the router and for the switch. Have you configured any router interface as a dot1q-trunk? Have you changed the native vlan in some of the units?
