Exchange server & ASA 5540 outside interface sharing same IP address?
May 14th, 2008
Hi Gurus
Need some assistance here?
1.Need email access from outside but don't have a dedicated public IP for mail server. Can i share the same IP for both like the way ISA works? i.e PAT inside to outside then static NAT for exchange IP to public IP & allow smtp access from outside?
2. Need to inside to access DMZ without translation. I have done this:
interface GigabitEthernet0/1
nameif IF_LAN_INSIDE
security-level 100
ip address 172.31.1.2 255.255.255.0 standby 172.31.1.3
interface GigabitEthernet0/2
nameif IF_DMZ
security-level 50
ip address 192.168.168.1 255.255.255.248 standby 192.168.168.2
static (IF_LAN_INSIDE,IF_DMZ) 172.31.1.0 172.31.1.0 netmask 255.255.255.0
but i cant access DMZ from INSIDE
removed the static command and did this:
access-list INSIDE_TO_DMZ_NONAT extended permit ip 172.31.1.0 255.255.255.0 192.168.168.0 255.255.255.248
nat (IF_LAN_INSIDE) 0 access-list INSIDE_TO_DMZ_NONAT
this didn't work still. enable nat-control to no avail.
the only thing that works is nating from inside to DMZ.
any pointers?
solomon
smahbub Tue, 05/20/2008 - 09:10
  • Silver, 250 points or more
In PIX 6.0, the Port Redirection(Forwarding) feature was added to allow outside users to connect to a particular IP address/port and have the PIX redirect the traffic to the appropriate inside server; the static command was modified. The shared address can be a unique address, a shared outbound PAT address, or shared with the external interface.
when a host on one PIX Firewall interface initiates a connection to a host on another interface, the PIX must have a way to translate that host's IP address across itself. Even if it is not necessary for the IP address to be translated, a translation must still occur. Therefore, in order to allow hosts on the inside access to hosts on the DMZ, a translation that does not actually translate must be configured.
Refer the following url for more info on allowing Inside Hosts Access to a DMZ without Translation:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094aad.shtml#dmz
