ADSL / SHDSL clarifications
May 14th, 2008
Hi Techies,
Could someone clarify my below doubts,might be a silly question , but sometimes need to double check with DSL gurus....
1.I have a router (2801) with SHDSL card , will my card support and compatible with the Assymetri DSL connection from my ISP ?
or need to go for WIC-ADSL 1 card ?
2.if so which annex mode "dsl-mode shdsl symmetric annex" should i choose ?
3.My aggregation router / DSLAM is Huwaei based , will it be an issue running cisco based client (cisco router with ADSL modem - cpe) in my end?
4.if so , is there any specific configuration needs to be done on the client side or Huwaei side ?
5.could you please give me the basic ADSL configuration cisco url with authentication and ppp callin setup?
thanks in advance.
Sakthi
smahbub Tue, 05/20/2008 - 05:48
  • Silver, 250 points or more
I think that it is better to use WIC-ADSL 1 card for ADSL connection fron isp. To configure a DSL controller to operate in SHDSL multirate, high-speed symmetric mode, and to set regional operating parameters, use the dsl-mode shdsl symmetric annex command in controller configuration mode.Refer the following url for more info on the command:
http://www.cisco.com/en/US/docs/ios/12_3t/wan/command/reference/wan_d1gt.html#wp1060177
Refer the following url for exmpales on configuring ppp authentication
http://www.cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a0080093e67.shtml
