Disable the wireless network card upon connection.
May 14th, 2008
Has anyone done the following, if so can you provide some insite on how to do it and how well it works....If wireless networking is not being used in the organization, it is possible for CSA to disable
the wireless network card when it is connected to the corporate network. I'm assuming by using the system
state variable with the rule, you can allow laptop users the ability to use wireless when they are
not connected to the corporate network.
tsteger1 Thu, 05/15/2008 - 11:57
  • Red, 2250 points or more
You cannot disable the wireless adapter but you can deny any traffic using a system state.
The system state "Ethernet Active" can be used with a NAC rule to prevent any wireless traffic.
Tom
bruce_sprenger Thu, 05/15/2008 - 12:48
I dont' see a system state "ethernet active" do I create this? I'm on CSA version 5.1.0.103. I have a system state called network which has the description of All users who are logged on via a network connection. Is that the same thing you mean? Then how do I create the rule? I get to where I have a NAC rule but I'm not for sure what to choose after that.
tsteger1 Thu, 05/15/2008 - 16:20
Sorry about that, 5.1 doesn't have it.
I was referring to 5.2.
Tom
