Remote VPN Problem
May 14th, 2008
My remote access vpn client is not able to connnect with internal network.
concentrator is connected with core switch and server 172.28.31.171(server) is also connected in core switch.
InterVLN routing is working fine. server and conncentrator is able to reach other via core switch.
concentrator private Ip address 172.28.31.92/248
VPN POOL: 172.28.31.128/248
Core switch Ip address is 172.28.31.91
Client is able to connect without any problem, but client not able to ping or connect with any network device.
In VPN session i can see bytes send and receive. My LAN-2-LAN tunnles are working fine without any problem.
No firewall involoved in the path between the concentrator and desired server 172.28.31.171.
Both connected on same switch but different VLAN. Inter VLAN routing is working and both are able to ping.
ONly remote access client 172.28.31.128/248 is not able to reach anywhere.
Core switch routing table
ip route 172.28.0.0 255.255.0.0 172.28.31.68
ip route 172.28.0.0 255.255.224.0 172.28.31.77
ip route 172.28.31.128 255.255.255.248 172.28.31.92
ip route 172.28.32.50 255.255.255.255 172.28.31.92
ip route 172.29.0.0 255.255.0.0 172.28.31.68
Concentrator routing table
172.28.31.160 255.255.255.224 via 172.28.31.91
172.28.92.0 255.255.255.0 via 172.28.31.91
172.29.0.0 255.255.0.0 via 172.28.31.91
192.168.0.0 255.255.0.0 via 172.28.31.91
172.28.31.170 255.255.255.255 via 172.28.31.91
Split tunnel is enable for
172.28.31.88/0.0.0.7
192.168.0.0/0.0.255.255
172.29.0.0/0.0.255.255
172.28.92.0/0.0.0.255
172.28.31.170/0.0.0.0
172.28.31.171/0.0.0.0
Please help me out, more than 10 days has passed but still not solution.
srue Wed, 05/14/2008 - 06:12
  • Blue, 1500 points or more
on your core switch, see if IPs from the pool range are even hitting the switch:
access-list 100 permit ip 172.28.31.128 0.0.0.7 any
deb ip packet 100
