RTD for call control
May 14th, 2008
There is a recommended min. 150 RTD for voice but is there a min. for call control. I`m thinking of deploying SRST cluster but only send Call Control across the Link with local telco traffic via a local T1- Th elink back to teh central system has long delays on it . All IPT calls will either be on the same router so no WAN traffic except Call Control or via the E1. There may be a local CUE or not
Many thanks
iptuser55 Wed, 05/21/2008 - 00:18
Thanks for your reply but I`m looking for details on call control and is there a delay limit as in voice or are they the same i.e 150ms. Teh idea is that we only send call control across the WAN due to size of the link for voice etc
Jaime Valencia Wed, 05/21/2008 - 05:58
i'd say it's a little more resistant to delay, but in any case i'd keep it below under 200 ms. otherwise the delay would be noticeable by the users ie, delay in dial tone, delay on call establishment, delay on softkey response, etc
javalenc
if this helps, please rate
