Print list of AP wireless MAC's
May 14th, 2008
Everyone,
I have 150 LWAPP AP's connected to 3 4400 controllers running 5.0.148 and managed by WCS. My company specifies that we must use Air Defense as a wireless IDS system (don't get me started) so I need to load all my MACS into Air Defense so it knows what is an authorized AP. I need to be a able to run a report listing every wireless MAC address currently in use so that I can do an import and so far I cannot figure out how to do it! I would think this would be simple but I guess not. Anyway, does anyone have any idea how to do this?
Prefereble the output would be a CSV with the following fields:
AP name,SSID,radio(a,b,g),wireless mac
Thanks in advance.
Overall Rating: 5 (1 ratings)
jeromehenry_2 Wed, 05/14/2008 - 09:33
  • Silver, 250 points or more
Mmm, I can't think of any simple way of doing this from the controller... I would run a show client summary, which gives client MAC, AP, radio... you are missing the SSID, which is given with the show client detail (but too extensive)... then copy paste to a word to change spaces to tabs, and then excel for CSV... not the easiest way.
Of course, if you have WCS, you simply run a client association report and export to CSV... maybe do you have a SNMP management station you could send the SNMP clients information to?
hth
Jerome
Nathan Spitzer Wed, 05/14/2008 - 09:50
Sorry, I was not clear. I need the MAC's of the AP's themselves, not of the clients.
In addition, I am an awk/sed kind of guy so if I get to much information, thats OK as I can parse that out in a sec.
ericgarnel Wed, 05/14/2008 - 11:00
  • Gold, 750 points or more
You can do this via WCS using the inventory report and select CSV as your output. You also can email the results as well
Nathan Spitzer Wed, 05/14/2008 - 11:30
Whenever I do this I get the ethernet MAC but not the Wireless Mac(s)
ericgarnel Wed, 05/14/2008 - 11:38
It can be done thru reports| Access point reports| AP profile status.
You can pick & choose how you want the report broken down
You can also export it and use sed+awk. You will want the 2nd column
Nathan Spitzer Thu, 05/15/2008 - 05:48
Guys, you cannot do what I want, but here is the details of a TAC case I opened for posterity:
Problem Details: Current setup:
2 SSID's
3 x 4400 WLC's running 5.0.148
138 x 1242 AP's
WCS 5.0.56.2
My corporation mandates the use of a third-party tool for Wireless IDS. In order for this
to work I need to import a file with the following information:
AP Name,SSID,Wireless MAC
I cannot find out how to figure out what MAC is currently being used to broadcast a
particular SSID. All reports in WCS I can find return the base MAC, not the MAC an AP is
using to actually broadcast a particular SSID. For example, I have an AP with a base MA of
00:19:a9:fe:90:50 broadcasting 2 SSID's:
AP1 SSID1 00:19:a9:fe:90:5f *Notice the last charater of the MAC!!
AP1 SSID2 00:19:a9:fe:90:51 *Notice the last charater of the MAC!!
I need a report that returns the information above
Answer:
believe you are trying to find every BSSID Mac address that is in your wireless network. Unfortunately, there is no way to generate a report of all of these mac addresses. However, there is a systematic way to find the mac addresses from the base radio mac (which is listed in the controller/wcs)
There will be a different mac for both the B/G radio and the A radio per WLAN.
For this example I'm going to assume the base radio MAC ends in "d0".
(The very last value in radio MAC is always 0)
To get the B/G Radio SSID MACs:
Start at the base radio MAC and increment for each WLAN ID....
WLAN 1 ends in d0
WLAN 2 ends in d1
WLAN 3 ends in d2
WLAN 4 ends in d3
etc...
To get the A Radio SSID MACs:
Start with the last value 'F' and decrement for each WLAN ID...
WLAN 1 ends in df
WLAN 2 ends in de
WLAN 3 ends in dd
WLAN 4 ends in dc
etc...
Using this pattern, from 00:19:a9:fe:90:50, you found:
00:19:a9:fe:90:5f -- this would be WLAN 1 for the A Radio
00:19:a9:fe:90:51 -- this would be WLAN 2 for the B/G Radio
You should also have 2 more mac addresses from this AP:
00:19:a9:fe:90:5e -- WLAN 2 for the A radio
00:19:a9:fe:90:50 -- WLAN 1 for the B/G Radio
So each SSID will have 2 specific mac addresses, one for each radio.
Please let me know if you have any other questions on this topic or if I can be of further assistance.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
