dial peer
Answered Question
May 14th, 2008
I have two groups of ANI (calling numbers). "Group A" is 2102xxxx, "group B" is "3100xxxx"
I would like to config "group A" users to make IDD (A to Z) via carrier A
and
I would like to config "group B" users to make IDD (A to Z) via carrier B
two group of users call the same toll free number 8001234.
e.g.
21021234 makes an IDD call, he dials
"8001234 then, 0018861234567" --> carrier A
31001234 makes an IDD call, he dials
"8001234 then, 0018861234567" --> carrier B
I use the "answer-address" to control the incomimg ANI but I fail. any idea how to config the dial peer?
rdgs
Overall Rating: 5 (1 ratings)
paolo bevilacqua Wed, 05/14/2008 - 06:29
  • Hall of Fame,
    Founding Member
You can use two techniques: COR or "steering digits"
On the incoming DP with answer-address, configure either a COR, or translation-profile to add special digits in front of number.
On the outgoing, you create two DP. With cor, each one will have the proper cor setting. With steering digits, you modify destination-pattern to match the special digits, and again a translation-profile to strip the digits.
anitachoi3 Wed, 05/14/2008 - 06:41
I try following config but fail. any missing?
rdgs
! R1
dial-peer voice 86601 pots
answer-address 2102.
direct-inward-dial
port 6/0:D
prefix 234
dial-peer voice 23401 voip
destination-pattern 234.
session protocol sipv2
session target ipv4:192.168.0.1
dtmf-relay rtp-nte digit-drop h245-signal h245-alphanumeric
dial-peer voice 86602 pots
answer-address 3100.
direct-inward-dial
port 6/0:D
dial-peer voice 86603 voip
destination-pattern 001.
session target ipv4:172.16.1.1
paolo bevilacqua Wed, 05/14/2008 - 06:43
  • Hall of Fame,
    Founding Member
It doesn't work because you need to apply one or the other technique I've suggested above, but your config doesn't.
anitachoi3 Wed, 05/14/2008 - 06:49
hi,
How to config "a COR, or translation-profile to add special digits in front of number"
I do not have any idea to config it.
rdgs
Correct Answer
paolo bevilacqua Wed, 05/14/2008 - 07:26
  • Hall of Fame,
    Founding Member
