05-14-2008 06:38 AM - edited 03-17-2019 09:22 PM
When sending VoIP calls, how do you add "+" sign to the called number?
For example,
A number comes into the gateway as 011521234567
How do you modify the number so you can send it out as 52+1234567 ?
Solved! Go to Solution.
05-14-2008 06:47 AM
+ in the middle of a number doesn't make sense.
If you want to add in front of the number, you can use voice translation-profile and rule to do that.
05-14-2008 06:47 AM
05-14-2008 07:30 AM
Thank you for your response.
05-14-2008 07:31 AM
Thanks for the nice rating and good luck!
