iBGP as IGP in DMVPN Problems
May 14th, 2008
Is it possible to run iBGP as the IGP in a DMVPN (instead of EIGRP\OSPF) ?
I am testing a deployment scenario where the iBGP connection always fails after initially coming up (stays up for around 30 minutes. The spoke says that it did not get the BGP keepalive message, while the Hub appears to be sending the keepalives.
If I run EIGRP then the same setup works fine and the EIGRP neighbor relationship never goes down.
Is iBGP not supported in DMVPN ? OR Is there some special NHRP configuration required for this ?
The Hub has a Public IP, while the Spoke is behind a firewall and using NAT-T for the IKE\IPSec setup.
mchin345 Wed, 05/21/2008 - 05:32
BGP is an exterior routing protocol, and thus only advertises prefixes you specify with a corresponding next-hop address. Also with BGP, when establishing peerings between IBGP routers i.e. BGP routers in the same AS, you will need to establish a full mesh setup - either by configuring separate TCP sessions between spokes or using route-reflectors or confederations.
