Problem with my 2801 voice H.323 gateway
May 14th, 2008
Dear all,
Please I have a problem with my H.323 Voice Gateway. I use a cisco 2801 with VIC2 - BRI-NT/TE and FXO cards. when i debug isdn q931, i get the follwing error message:
- *May 14 15:13:18.359: ISDN BR0/1/1 Q931: Applying typeplan for sw-type 0x1 is 0x
0 0x0, Called num.
Could you please let me know what can cause this problem ?
thanks in adavance,
paolo bevilacqua Wed, 05/14/2008 - 07:22
  • Hall of Fame,
    Founding Member
It is only a message, doesn;t cause any problem, and it happens all the time, nothing to worry about.
Ayad Wed, 05/14/2008 - 09:31
but the problem is that i cannot not make any outgoing calls ???
how to resolve the issue?
Jaime Valencia Wed, 05/14/2008 - 09:43
  • Cisco Employee,
  • Hall of Fame,
    2011
with just that message there is no way to tell, post the whole config and explain the problem as detailed as possible
javalenc
paolo bevilacqua Wed, 05/14/2008 - 09:44
  • Hall of Fame,
    Founding Member
Collect and send "debug isdn q931" with "term mon". Also specify if you have CME, CM h.323 or MGCP or what else.
Ayad Thu, 05/15/2008 - 09:09
Please find attached the information requested (shrun, shver, debug isdn and ccapi inout). waiting your feedback.
Thanks in advance,
paolo bevilacqua Thu, 05/15/2008 - 09:20
  • Hall of Fame,
    Founding Member
Are your BRI circuits in group ? If so you will need "isdn static-tei 0" under each interface. Then I suggest you configure said BRIs in trunk-group to simplify configuration.
As an appreciation to those providing answers, please rate useful posts with the scrollbox below!
Ayad Thu, 05/15/2008 - 09:34
thanks for your prompt feedback. I have added this commande and i see the isdn status : channel0: MULTIPLE_FRAME_ESTABLISHED
channel1: TEI_ASSIGNED
When i debug isdn q931, i cannot see anything for incoming/outgoing calls ??
However, I get some traffic when i debug voice ccapi inout. what can cause this ?
paolo bevilacqua Thu, 05/15/2008 - 09:36
  • Hall of Fame,
    Founding Member
Your pots DP are strange. Make thyem something reasonable like patterns of number you are calling. Place interface in trunk-group so you have only on Dp to configure referencing the trunk group.
Ayad Thu, 05/15/2008 - 09:40
I have configured the DP 4 to route calls to my mobile (just for testing). could you please explain if it's a problem of config or others ? this configuration was working before.
thanks,
Ayad Thu, 05/15/2008 - 10:04
I will just add, when i debug isdn q931 and csim start command (to my mobile matched by DP number 4), i cannot see any isdn messages??? just :
0 0x0, Called num mynumber and
ISDN BRI0/0/0 q931: L3_Shutdown: Shutting down ISDN Layer 3 ??
Appreciate your help and assistance,
paolo bevilacqua Thu, 05/15/2008 - 10:13
  • Hall of Fame,
    Founding Member
You DP 4 is absorbing all the digits because you did not configure "forward-digits all" or "no strip-digits". Hence, null called number and no call.
