ACS 1113 console ThinkVantage Secure Data Disposal
May 14th, 2008
  • Bronze, 100 points or more
I plug into a RMA ACS 1113 SE and get the following;
ThinkVantage Secure Data Disposal Utility 3.
Date and Time of execution... 04/09/08 03:03:49:10
Command executed.....a:\scrub\scrub3.exe /d=ALL /l=2
Return Code.....0
I assume the RMA was 'cleaned' but never got the Cisco Secure software loaded, and I should get another RMA?
Jagdeep Gambhir Wed, 05/14/2008 - 07:35
  • Red, 2250 points or more
You need to reboot using the recovery CD for ACS SE.
~JG
Do rate helpful posts
Jason Aarons Wed, 05/14/2008 - 07:40
Do all RMAs units sent from depots require you to run the Recovery CD (which everyone tends to lose)?
Jagdeep Gambhir Wed, 05/14/2008 - 07:43
Yes, that is correct. You need to reimage. If you dont have that then pls open a tac case.
~JG
