LMS 3 -IPM -IP SLA
Answered Question
May 14th, 2008
I have a router in the DCR which supports IP SLA, IP Adv Services 12.4 ..
and SNMP v3 configured as read and write view mib-2 included.
When i import it into the IPM, it detects it as not IP-SLA enabled.
If there is anything else I need to do
Correct Answer by Joe Clarke about 8 years 8 months ago
mib2 view is not sufficient. Try using the built-in v1default view instead.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Wed, 05/14/2008 - 08:08
ashley_dew Wed, 05/14/2008 - 09:57
Thank very much, your solution solved my problem. The IPM now recognizes the router as IP SLA enabled.
Great job.
Cheers,
Ashley
