Using plink to connect to pix works (ssh), to switch doesn't work (telnet)
May 14th, 2008
I want to automate a few things using plink. I can connect interactively to a cisco pix using the following command:
plink -ssh -l username -pw password -m testconpix.txt 10.1.1.2
The contents of testconpix is:
en
enablepassword
sh arp
This works fine. I am authenticated and the output of the arp table is displayed.
Now, I would like to do the same to connect to a cisco switch using the following command:
plink -telnet -m testconsw.txt 10.1.1.10
The contents of testconsw.txt are;
telnetpw
en
enablepw
sh ip arp
However, I am prompted for the telnet password at the command line. It appears that the plink command is unable to read the file. What do I have to do to get plink to read the file interactively to logon and issue the commands?
murray-davis Wed, 05/14/2008 - 13:15
Well, I figured it out. Apparently, telnet can only read from the command line, not from a text file. So, I switched to the python programming language because it has a telnetlibrary and used the following script: telnet.py. I ran this script from a command line. The script logs on interactively and then prints out the arp table of the switch.
import telnetlib
HOST = "10.1.1.10"
tn = telnetlib.Telnet(HOST)
tn.read_until("Password: ")
tn.write("telnetpassword\n")
tn.write("en\n")
tn.write("enablepassword\n")
tn.write("sh arp\n")
tn.write("exit\n")
print tn.read_all()
