Relocate CUCM 6.1 Publisher
May 14th, 2008
Hi all,
A customer plans to relocate a CUCM6.1 publisher to a new site with a new hardware and a new IP address. Hence, the IP address should be changed. According to replacing a single server or a cluster for CUCM 6, all subscribers should be reinstalled after replacing publisher. But, the IP address of publisher should remain unchanged.
Please advise what the procedures of relocating CUCM6.1 publisher are.
Thanks&Rgds,
YB
Overall Rating: 5 (1 ratings)
Rob Huffman Wed, 05/14/2008 - 08:38
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi YB,
The method for changing a 6.x CCM Address in nicely detailed in this doc;
Changing the IP Address for Cisco CallManager
From this excellent doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094601.shtml
Hope this helps!
Rob
Yuk Bor Lau Wed, 05/14/2008 - 18:01
Hi Rob,
Thanks for your reply. But, because I need to replace the hardware as well, I want to know what the correct sequence shoud be.
1. Change IP -> Replace hardware -> Reinstall subscribers
2. Replace hardware -> change IP -> Reinstall subscribers
3. Replace hardware -> Reinstall subscribers -> change IP
I'm not sure which option of the above 3 options is the best.
Please help.
Bor
Rob Huffman Thu, 05/15/2008 - 04:21
  • Hall of Fame,
    Founding Member
Hi Bor,
Sorry I missed that :) My vote would be for #3. Make sure the re-build is successful and that replication is working properly before changing the IP.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/6_1_1/cluster/clstr611-pdf.pdf
Hope this helps!
Rob
