Can't ping server in DMZ1 from Inside interface
May 14th, 2008
Hi all, I cannot ping a server that has ip 62.15.25.25 from a server that exists on an Inside interface with the ip of 172.17.2.50.
In our PIX 515, I have the following references to our references to either server.
nat (inside) 2 172.17.2.50 255.255.255.255 0 0
static (inside,outside) tcp 62.15.25.26 smtp 172.17.2.50 smtp netmask 255.255.255.255 0 0
aaa-server authinbound (inside) host 172.17.2.50 testkey timeout 10
access-list 101 permit tcp host 62.15.25.25 any eq smtp
access-list 101 permit ip host 62.15.25.25 host 172.16.2.1
access-list 101 permit ip host 62.15.25.25 host 172.17.1.32
access-list 30 permit tcp any host 62.15.25.25 eq domain
access-list 30 permit udp any host 62.15.25.25 eq domain
static (dmz1,outside) 62.15.25.25 62.15.25.25 netmask 255.255.255.255 0 0
static (inside,dmz1) 62.15.25.25 172.17.2.120 netmask 255.255.255.255 0 0
Any ideas?
srue Wed, 05/14/2008 - 11:20
  • Blue, 1500 points or more
you've only posted bits of the config....which are useless without other parts.
whatever acl is applied to your dmz interface, add something like:
access-list acl_name permit icmp any any echo-reply
or turn on icmp inspection if running 7.x or later.
acomiskey Wed, 05/14/2008 - 11:51
  • Green, 3000 points or more
What is this static supposed to do?
All you should need is...
static (inside,dmz1) 172.17.2.0 172.17.2.0 netmask 255.255.255.0
Then ping 62.15.25.25
slayerhawk Wed, 05/14/2008 - 11:52
I'm not sure what that static does, I am new to PIX.
slayerhawk Wed, 05/14/2008 - 11:53
The interesting thing is that all other servers on the 172.17.2.0 subnet can ping the 62.15.25.25 address....Just 172.17.2.50 cannot ping it.
slayerhawk Thu, 05/15/2008 - 05:10
I found this statement in the PIX and I don't know what it does. Can someone explain what it does for me?
I removed it from the PIX and my 172.17.2.50 server was then able to ping the 62.15.25.25 address.
Any ideas?
acomiskey Thu, 05/15/2008 - 05:47
There should also be a corresponding global statement with the number 2.
global (xxxxx) 2 ....
slayerhawk Thu, 05/15/2008 - 06:27
I do have global statements that look like this, but they don't reference the ip address of 172.17.2.50.
global (outside) 2 xxx.xxx.xxx.xxx
These global statements only reference extneral ip addresses, but not the DMZ.
