Cisco VPN Client Random Disconnects
May 14th, 2008
I am connecting to our ASA5510 via Cisco VPN client version 5.x. I am getting continuous disconnects at random times. I have never had a connection last more than 10 minutes. The disconnects happen when the session is idle and also when the session is active. I have had the connection drop on me in the middle of a file transfer even. I have set the session timeout to unlimited but no help. Does anyone have any ideas?
Ken
smahbub Tue, 05/20/2008 - 05:57
The reason for that disconnection might be one of the following:
1) You reached an idle timeout.Increase the idle timeout value.
2) Someone cleared the tunnel.check for the tunnel configuration.
3) Your SA has a very short lifetime.
check if isakmp nat-t is enabled.If not enable the same and check for the issue.
check if TunnelEstablished Registry key is set to 0 which is the right one.
Refer the following url for more info on troubleshooting VPN issue:
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a00807e0aca.shtml#isalife
