Initiate a VPN session from the inside
May 14th, 2008
I have an problem configuring an ASA...
Look at the attached diagram...
My internal users are used to connecting to this Remote Access VPN (which used to be on a 3030 where this worked) using the "outside" interface address.
Since installing the ASA I have not been able to get this to work. Users out on the Internet can connect to the outside interface with no problem. The internal users are having to use the inside interface.
TAC says I can't do this but I am not sure they understand the problem. Can someone out there take a look at this?
Thanks for any help!
