CUCM 6.0 Mobility
May 14th, 2008
I got mobility working with CM6, however the end users would like to reach the cell phone voice mail and dont come back to the deskphone for voicemail.(keep the message at the cellphone) I've tried multiple combinations of the timers
Answer Too Soon Timer
Answer Too Late Timer
and Delay Before Ringing Timer
however the call keeps coming back to the deskphone then voicemail.
Any ideas
thanks
Armando
sheepate Wed, 05/14/2008 - 12:45
- Extend the "Answer Too Late Timer" timer beyond the CFNA to VM timer by about 2 seconds.
- Decrease "Delay Before Ringing" timer to minimum.
Basically Cell phone VM needs to answer the call before Answer too late timer expires.
HTH.
aramos17428 Wed, 05/14/2008 - 13:27
Ok I did that but the call keeps going back to the deskphone voicemail.
The CFNA to VM timer is service parameters is 20 and the Answer Too Late Timer is set to max (300000) and the Delay Before Ringing is set to Minimum (0.) Basically, users dont want the call to go back to the deskphone.
Armando
evanrichards Tue, 05/20/2008 - 15:52
I experienced that exact same problem when getting mine set up. The very first thing you need to know is how long the cell phone (or other device) will ring before it goes to voice mail. Call this value 'X'. Once you have that information you just need to set the 'Answer too late time' for a longer period than 'X.' For example, if your cell phone rings for 35 seconds before going to voice mail, set your 'Answer too late timer' for 40 seconds.
