as-path prepend
Answered Question
Hi there
When you use as-path prepend, and you are adding an as-path multiple times, why is this not concidered as a loop, after all you will have the same AS number appearing
multiple times
Cheers
Per
Correct Answer by Harold Ritter about 8 years 11 months ago
Per,
An AS-PATH loop occurs when a BGP router received an update from a remote AS with its own AS in the AS path.
Seeing a given AS more than once in an AS path is not a AS loop unless it is has been it your own.
Overall Rating: 5 (1 ratings)
Correct Answer
Harold Ritter Wed, 05/14/2008 - 17:46
  • Cisco Employee,
Per,
