Meetingplace Express Error
May 14th, 2008
We are having some issues with a meetingplace express system where we get busy signals. In looking at the system, there are plenty of available ports, and the calls get busy signals internally so the we know that it is not a pri issue. I noticed that we are getting some errors in the logs.. anyone know what these mean? We have an H.323 integration with call manager 6.1(2) (same issue with 6.1(1a) previously too.
05/14 14:06:40.34 WARN 0x20002e 0/32, "mp_calls.cc", 5417 (0x1487, 0, 0, 0)
Call failed in ConfSched, error=5255
05/14 14:06:47.89 WARN 0x2002c 0/5, "cssess.cc", 335 (0xe3c00004, 0xff2, 0x3, 0x3)
Connection ID Already known... Con ID = -473956348
05/14 14:08:14.72 INFO 0x2011d 0/5, "csschedparams.cc", 3009 (0x28, 0, 0, 0)
Schedulable Voice Ports = 40
irisrios Wed, 05/21/2008 - 06:16
  • Silver, 250 points or more
This error message is due to partinfo call made through nmpagent. The error code means that the participant was not in the conference. Audio and Video calls are not impacted by this. It might be called in a outdial scenario. This does not cause call failures. The "Call Failed" message happens to be what nmpagent logs when the API call filed for participant info.
KEVIN STEWART Wed, 05/21/2008 - 08:27
Thanks for the reply.. I ended up figuring out the issue.. the locations were setup wrong and we were getting out of bandwidth busy signals..
