Cisco NAC problem with Vista
May 14th, 2008
I've deployed a Cisco NAC solution (utilising CCA 3315) in a OOB Virtual Gateway deployment. So far it's working great on XP clients with single sign-on. However when run on Vista clients a problem occurs when the user idles and the screen locks. When the user logs in again, the NAC agent keeps prompting the user to accept a cert repeatedly. Anyone come acrosss this problem and the workaround/solution?
version is 4.1.3.2
thanks
Overall Rating: 5 (1 ratings)
pcomeaux Mon, 05/19/2008 - 17:56
  • Cisco Employee,
Hi -
I searched all opened/closed TAC cases for you to see if this was a common issue. I do not see any cases related to this.
My suggestion would be to open a TAC case and get help right away on this issue.
thxs
peter
