modify a global keepalive on css 11500
May 15th, 2008
how can I modify a global keepalive on a css 11500?!
I mean, I have create a keepalive
es:
keepalive concors_ris
type http
frequency 10
uri "/risultati-concorsi/"
I want to modify this keealive, but I cannot.
I also cannot remove this one.
Can anyone help me?!
Best Regards
Cinzia
Gilles Dufour Thu, 05/15/2008 - 04:00
  • Cisco Employee,
What kind of error do you get when you try to remove it ?
This could be the following ddts : CSCek41097 "Ghost Keepalives cannot be removed".
I would recommend an upgrade to the latest 8.10 or 8.20 image.
Gilles.
csiracusa Thu, 05/15/2008 - 04:40
Hi Gilles,
when I try to remove it, the message is
%%Keepalive does not esist
This occur after this:
when I try to assegnate the keepalive to a service the message I receive is
%% Maximum keepalives of this type have been exceeded. Cannot activate
After this I cannot use the defined keepalive at all.
Thanks a lot
Best Regards
Cinzia
Gilles Dufour Thu, 05/15/2008 - 04:44
  • Cisco Employee,
It confirms this is a match to CSCek41097: Ghost Keepalives cannot be removed
You should upgrade to 8.10(405) or later
Gilles.
