ASA simple setup
May 15th, 2008
I have problem pinging from inside interface to outside interface and also from outside interface to interface. I have included sh run and sh ver command with this email. I wanted to try this simple setup first.
ciscoasa# sh run
ASA Version 7.0(7)
hostname ciscoasa
domain-name default.domain.invalid
enable password xxx
names
dns-guard
interface Ethernet0/0
nameif outside
security-level 0
ip address 209.x.x.225 255.255.255.0
interface Ethernet0/1
nameif inside
security-level 100
ip address 10.10.10.1 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
passwd xxx
ftp mode passive
access-list outside_access_in extended permit tcp any any
access-list inside_access_in extended permit tcp any any
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu management 1500
no failover
asdm image disk0:/asdm-507.bin
arp timeout 14400
nat-control
global (outside) 10 209.165.200.230-209.165.200.240
global (outside) 10 10.10.10.1
global (inside) 10 interface
nat (inside) 10 0.0.0.0 0.0.0.0
nat (management) 10 0.0.0.0 0.0.0.0
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
Cryptochecksum:xxx
: end
srue Thu, 05/15/2008 - 04:32
  • Blue, 1500 points or more
the asa doesn't let you ping a far side interface. you can only ping the asa interface that is closest to the source host of the ping.
the easiest way to configure ping *through* the firewall is to turn on icmp inspection:
inspect icmp
