vpn connection gets disconnected after some time
May 15th, 2008
Hello, I will provide two configurations, one is the vpn concentrator config and the other is the configuration of 1 client router that is connecting. I have marked on the configuration where the problem is.
Thank you and if you have any doubt please post it, I will try to do my best to let you know. Thanks.
