Warning message
One ACS supports 2 LMS ???
May 15th, 2008
Hi guys,
I have today one LMS 2.6 using an ACS 4.0.
Can I add a new LMS (3.0.1) into the same ACS without change the old one ??
So my question is if ACS 4.0 supports two LMS (differente versions) at the same time.
If yes, any recommendations ???
Thanks in Advanced
My Best Regards,
Andre Lomonaco
lomonaco Thu, 05/15/2008 - 05:32
In the same question.
Should I use the same System Identify User
or it is better create a new System Identify User for the new LMS ???
Thanks in advanced
Andre Lomonaco
Joe Clarke Thu, 05/15/2008 - 18:46
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You can use the same System Identity User. It would probably be easier that way.
Joe Clarke Thu, 05/15/2008 - 18:45
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes, assuming LMS 3.0.1 is registered to the ACS server after 2.6, that will work. Note: you will lose any custom roles you defined with LMS 2.6.
