netflow - router time sync problem
May 15th, 2008
i have configured router and netflow analyzer, but i receive "router time is not in sync" message. So i cannot obtain interfaces' descriptions or speed information.
there is a firewall between router and netflow pc. I am using NAT option for netflow pc. I configured firewall for port 9996 and there is no blocked packet between router and netflow. everything seems fine.
I checked configure options many times on both router and netflow every thing seems correct. ı beware time and timezone on both of them. But they are not synchronizing.
I also configured an other router and an other netflow (however there is not any firewall between them) and i dont have any problem on there.
My router which has sync problem with netflow is cisco 3700 series. I test both Netflow Analyzer 6.0 and 7.0 Beta. I dont find anything to correct problem. Is anybody have an idea
Thanks everyone
Jan Nejman Thu, 05/15/2008 - 06:51
  • Bronze, 100 points or more
Did you configure NTP protocol on the collector and on your router? On the router you can configure ntp as master/referrence and on the collector you can use for example ntpdate utility with synchronization from router once per hour.
Jan Nejman
Caligare, Co.
http://www.caligare.com/
