Cisco 857 Error when implementing Firewall
May 15th, 2008
Hi, I am in the process of setting up a Cisco 857 (12.4(15)T5), when trying to start the firewall via SDM or SDM Express I get the following error:
"class-map type inspect match-any sdm-cls-insp-traffic
Error detected at this command. Click OK"
Then the firewall config doesn't save, can anyone help me out with this please
Chris
spremkumar Fri, 05/16/2008 - 05:58
  • Red, 2250 points or more
Hi Chris
Can you confirm on what feature set you are running out there in your router ?
have you tried configuring any other firewall policy rules in the router ?
is it possible to try this config line via cli and check out if you are getting any error message out of it ?
regds
spremkumar Fri, 05/16/2008 - 06:02
Hi Chris
regds
shaw.chris Mon, 05/19/2008 - 02:10
Feature Set: C850-ADVSECURITYK9-M
When in configuration mode via the cli it doesn't even recognise class-map as a command.
Thanks.
