Analysis Engine not starting after 6.1 upgrade
May 15th, 2008
The Analysis Engine on my sensor is not starting after the upgrade to 6.1.
Also, when I use IDM to connect to the sensor it says:
Error connecting to sensor. Failed to create sensor - <IP address>.
Exiting IDM.
smahbub Wed, 05/21/2008 - 05:49
  • Silver, 250 points or more
Can you provide the output of commands "show tech" and "show version" which will help us in identifying the reason for the issue and resolving the same.
avang2004 Wed, 06/25/2008 - 05:57
You might be running into this bug #CSCsm71528
Symptom:
After signature update or configuration change the AnalysisEngine shows NotRunning.
Conditions:
After a signature update or other configuration change.
Workaround:
None, to restore service reboot sensor.
