upload speed
May 15th, 2008
Hi, I created a policy based route to take my server vlan and direct it to internet to a seperate T1. I wanted to separate workstation internet connection from the server internet connection. However I tested my link speed after configuring PBR, and my upload speed decreased drastically from 1.4Mbps to 700Kbps. The download speed did not change. I checked to see if there is any heavy traffic but there is almost no traffic on that link. Can simple PBR slow down the upload speed so much? Also when I remove the PBR the upload speed goes back to 1.4Mbps. I am using 2851 router which I believe should handle the PBR without any issues.
here is the config
route-map Server permit 10
match ip address 101
set ip next-hop x.x.x.x
access-list 101 deny ip 172.21.19.0 0.0.0.255 172.22.19.0 0.0.0.255
access-list 101 deny ip 172.21.19.0 0.0.0.255 10.0.0.0 0.0.0.255
access-list 101 permit ip 172.21.19.0 0.0.0.255 any
