Correct cable??
May 15th, 2008
I've recently installed a cisco 2811 with a VWIC2-2MFT-T1/E1 card.
BT is providing me:
Electrical Interface: G.703
Physical Connector: BNC 75 ohm unbalanced
I have already ordered a CAB-ADPT-75-120 adaptor cable. Now my question is:
what cable do I need to connect my router to the NTE / Adapter?
Thanks in advance!
Paolo Bevilacqua Thu, 05/15/2008 - 07:48
You don't need the adapter. You only need CAB-E1-RJ45BNC and configure "line-termination 75-ohm" under controller e1.
jo.keunen Thu, 05/15/2008 - 22:51
well yes, I found that out AFTER i ordered the adaptor...
anyway as I have the adaptor now, what cable do I need to use to connect it to the router?
Thanks in advance!
jo.keunen Fri, 05/16/2008 - 01:25
i've found what i need:
or a RJ48C pinout. (pin 1,2,4,5)
i've made a STP cable with this pinout and it works.
the advantage with the adaptor is that I can make a custom length cable.
