Tricky PBR
May 15th, 2008
I have PBR need that I am a little stumped on. Here is the scenario:
I have a host on the LAN that I would like to route all internet bound traffic to a "new" internet circuit, and all LAN bound traffic to be routed via LAN routing methods. No other hosts on the subnet, just this one host.
host: 10.9.100.25
gateway for LAN: 10.9.100.1
Gateway for Internet: 10.9.200.5
All other LAN subnets: 10/8
So I am stumped on how to change his defualt route to something other and route all 10/8 traffic to his LAN GW.
Thank you for any assistance with this.
t814687 Thu, 05/15/2008 - 08:35
Hi Chuck, little schematic of your network will help us to recommend the right solution.
-serg
chuckholley Thu, 05/15/2008 - 09:24
Thanks guys,
Here is a logical of the environment, I basically need to change the default route for this one user to the new NAT firewall to go to the new internet, and make sure he can still get to the corporate network.
Ahmede Thu, 05/15/2008 - 09:36
You can create PBR, and attach it to the interface 10.9.100.1,
in the PBR,
deny 10.0.0.0 0.255.255.255
permit any
Then next hop to the NAT firewall..
HTH..
Ahmed
chuckholley Thu, 05/15/2008 - 09:58
So the PBR would do the deny or the ACL? I would deny 10.9.100.5 to all 10/8, then the next hop to the NAT firewall?
t814687 Thu, 05/15/2008 - 10:08
This statement makes sure the traffic is routed (that's why "deny" is there) to your 10/8 and policy routed (permit any) to the new internet. Should work fine.
-serg
chuckholley Thu, 05/15/2008 - 10:23
OK, here is exactly what I have, and it is not working at the moment:
ACL:
10 deny ip host 10.9.100.5 10.0.0.0 0.255.255.255
20 permit ip host 10.9.100.5 any
Route-Map:
route-map Chuck permit 10
match ip address Chuck
set ip next-hop 10.9.99.5
t814687 Thu, 05/15/2008 - 10:28
did you apply this map to the router interface where your host is connected?
-serg
chuckholley Thu, 05/15/2008 - 10:32
yes, had to ask though right!
interface Vlan100
ip address 10.9.100.4 255.255.255.0
ip helper-address 10.9.43.13
no ip redirects
ip policy route-map Chuck
standby 1 ip 10.9.100.1
standby 1 priority 110
standby 1 preempt
end
t814687 Thu, 05/15/2008 - 10:36
And your acl is named "Chuck" ?
do you see any hits on the acl?
chuckholley Thu, 05/15/2008 - 10:43
The name of the acl is Chuck, and it is very strange, I see 3 hits on the deny, and none on the permit.
chuckholley Thu, 05/15/2008 - 10:50
There should be many hits on the acl is why it is strange.
t814687 Thu, 05/15/2008 - 11:02
So you generating traffic to the internet and see no hits on permit? can you check your new firewall if the traffic makes there and it allows that host to go out?
can you connect to 10/8 network?
what switch you using?
can you debug pbr ?
t814687 Thu, 05/15/2008 - 11:33
keep in mind for certain switch types (3750 for example) you can not use deny statementd in PBR ACLs... in this case you have to do an explicit route map statement and forward traffic to your 10/8 vlan interface.
chuckholley Thu, 05/15/2008 - 12:31
Thanks, this is working. We had a nat issue on our FWSM, but that is resolved not and we are surfing out the new internet.
Many Thanks!
t814687 Thu, 05/15/2008 - 12:39
Glad it worked - please use rating system ;)
-serg
interface Vlan100
no ip redirects
standby 1 preempt
end
