paolo bevilacqua Thu, 05/15/2008 - 08:39
  • Hall of Fame,
    Founding Member
First of all, you have atm overhead, makes a 155 mbps to be really 120 mbps or so.
http://sd.wareonearth.com/~phil/net/overhead/
Secondly, a 3845 might get close to max circuit utilization, but with significant CPU usage.
A 3825 would probably melt much before.
hope this helps, please rate post if it does!
mmasis Fri, 05/16/2008 - 10:30
  • Cisco Employee,
I really appreciate your effort, but i found it in a presentation on CEC; ISR are CPU based so it could reach higher performance, but basically the answer was yes.
Thanks!!! have a greate weekend!
paolo bevilacqua Fri, 05/16/2008 - 12:31
  • Hall of Fame,
    Founding Member
Here's attached "your" official numbers.
As you see for smaller packet size linerate cannot be reached. So in general don't count on a 3825 to be able "to fill the pipe" and still have CPU to spare. It won't.
mmasis Mon, 05/19/2008 - 05:37
  • Cisco Employee,
Thanks for the attached file is very helpfull.
