SSL Error when trying to use Citirx through ASA 8.0.3
May 15th, 2008
We are trying to connect to a Citrix presentation server web interface I have two different issues. If I use the ICA plugin I get javaIO errors. If I use https: instead if ICA: I get an ssl error about noth trusting the CA even though I addded it to the local java client. I have looked at the other posts that are similar and can not get pas either of these errors. If I go stright to the server with out the ASA using the same url as in the asa it is find and I do not get the ssl error
