VNC to Unity taking a long time or being dissallowed
May 15th, 2008
CSA is dissalowing VNC connections on a timely fashion with a message:
The Process c:\program files\realvnc\vnc4\winvnc4.exe is attempting to capture keystrokes. Do you wish to allow this?
I assume something has changed in the later CSA versions or possibly the combination of VNC 4, CSA, and Windows 2003. I have been using the same version of VNC for quite some time.
Anyone have any ideas?
Overall Rating: 5 (2 ratings)
tsteger1 Fri, 05/16/2008 - 09:55
Later versions of CSA separated the Trojan Detection rules into different rule modules.
The rule that tracks keystroke trapping in CSA 5.2 is a "System API control - All Applications, Trap keystrokes" and you'll need to create a separate exception for that.
Tom
shane.orr Sun, 05/18/2008 - 18:49
Well unfortunately I typically just use the standalone CSA with Call Manager and Unity but this is helpful information so thank you!!
