NAT Exemption
May 15th, 2008
Hi Experts,
I have two interface dmz(S. level 90) and wan(s. level 60) i have two nat exemption rule
nat (dmz) 0 0.0.0.0 0.0.0.0
nat (wan) 0 0.0.0.0 0.0.0.0
i have one another static nat rule:
static(dmz,wan) 10.10.10.10 10.10.10.10
when i try to removing this natting rule, i get connection loss from wan..
after adding same static rule again get connection from wan to dmz..
please revert with proper solution to exempt nat.
Thanks in advance.........
Amit
srue Sun, 05/18/2008 - 18:04
  • Blue, 1500 points or more
is nat-control enabled?
vabruno Tue, 05/20/2008 - 19:01
I believe is you do a no nat-control then you wont need any NAT statements because you are trying to push traffic from DMZ to wan with is a lower security level and with NAT-control no enabled that traffic will not get NAT'd anyways.
amit.secure1 Tue, 05/20/2008 - 20:21
Thnks for ur reply...
now i got another major solution that is not documneted on cisco site, i taking confimration from cisco for same changes.
now i am closing this coversation
