Configuring NM-1T3-E3 module on a 3845 Router
Answered Question
May 15th, 2008
When I installed an NM-1T3-E3 module in a 3845 Router and did a sho ip interface brief or sho controllers, the module does't appear to be installed; however, upon booting up the router the following information shows:
345 0X000F6400 Clear/Fractional 1 port T3/E3
1 Subrate T3/E3 port
Can someone tell me what I need to do to configure this module? This will be a P2P DS3 connection to headquarters.
Thanks in advance,
sK
Correct Answer by Richard Burts about 9 years 2 months ago
SK
Your configuration might look something like this:
card type t3 1
controller T3 1/0
clock source line
cablelength 10
! and any other controller parameters that you might need
interface Serial1/0
description whatever description you want
mtu 1476
bandwidth 44210
ip address 123.123.123.121 255.255.255.252
encapsulation ppp
keepalive 8
dsu bandwidth 44210
scramble
serial restart-delay 0
this is based on the configuration of a working router. Adjust whatever you need to fit your situation.
Rick
Overall Rating: 5 (3 ratings)
Richard Burts Thu, 05/15/2008 - 11:06
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
SK
What you need is a command to tell the router what kind of card (T3 or E3) it is dealing with. Use the command:
card type
and then you should see the serial interface in your config.
Rick
skhirbash Thu, 05/15/2008 - 11:15
Great! Thanks Rick. Now that I got the card recognized by the router, how do I configure the interface for a P2P connection?
In previous routers, I would use the S0 or S1 interface and configure the serial interface for a P2P connection but how do I do it with this T3 card on this newer router?
Thanks in advance,
sK
Correct Answer
Richard Burts Thu, 05/15/2008 - 11:34
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
SK
card type t3 1
controller T3 1/0
clock source line
cablelength 10
interface Serial1/0
mtu 1476
bandwidth 44210
encapsulation ppp
keepalive 8
dsu bandwidth 44210
scramble
Rick
Richard Burts Thu, 05/15/2008 - 12:14
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
SK
I am glad that my answers helped resolve your issue. Thank you for using the rating system to indicate that your issue was resolved (and thanks for the rating). It makes the forum more useful when people can read an issue and can know that there were responses which did resolve the issue.
The forum is an excellent place to learn Cisco networking. I encourage you to continue your participation in the forum.
Rick
TheNextBillGates Tue, 05/31/2016 - 18:56
Just bought a couple of these cards to put into my craigslist-facilitated homebrew CCNA lab, which includes a couple 2811s.  Had no idea what I was doing until now.  Thanks for your help!
Richard Burts Tue, 05/31/2016 - 19:35
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
I am glad that this discussion was helpful to you. These forums are a good place to learn about Cisco networking. I hope to see you continue to be active the forums.
Rick
