CM 6.1 - DHCP Usage
Answered Question
May 15th, 2008
Since upgrading to CUCM 6.1, I can't find how one goes about monitoring the DHCP usage of a particular subnet. I need to see how many, and which particular addresses are being used. I've been through the webadmin, the CLI, and the Real-time monitor, still can't find it..
Can someone please assist me?
Thank You
Correct Answer by ivillegas about 8 years 8 months ago
show ip dhcp-local binding
Use to display the mapping between the token or enduring IP address and the MAC address of the subscriber's computer.
show ip dhcp-local excluded
Use to display addresses that have been excluded using the ip dhcp-local excluded-address command. The DHCP local server does not allocate excluded addresses, because they are already used by devices on the subnet.
show ip dhcp-local limits
Use to display the maximum number of leases available for each VPI, VCI, VLAN, and Ethernet subnet.
show ip dhcp-local reserved
Use to display the static IP address/MAC address pairs that the DHCP local server supplies in standalone mode.
http://www.cisco.com/en/US/docs/ios/12_0t/12_0t1/feature/guide/Easyip2.html
Overall Rating: 5 (1 ratings)
Correct Answer
ivillegas Wed, 05/21/2008 - 07:51
