05-15-2008 11:08 AM - edited 03-05-2019 11:01 PM
I need to know how can I to put command with WR to save in form automatic the running-config of the switch 3750 but the save will have a TFTP o FTP.
The TFTP will have running-config as backup Anyone can help me?
Solved! Go to Solution.
05-18-2008 08:00 PM
In addition to EEM, you can also use the built-in config archive functionality. If you want to automatically archive configuration changes to a TFTP server, you can use the following sample config:
archive
path tftp://10.1.1.1/router.cfg
maximum 14
time-period 1440
That will archive the config to a TFTP server every 24 hours. It will archive a maximum of 14 configs. Before this will work, however, you will need to pre-create the files on the TFTP server. The files will be named router.cfg-1, -2, -3, ...
Note: this is a security risk, so be very sure your TFTP server is secure before archiving device configs.
05-16-2008 12:52 AM
I would take a look at the EEM scripting pages on CCO. Someone has created a script that should do what you want.
http://forums.cisco.com/eforum/servlet/EEM?page=eem&fn=script&scriptId=346
I would look into it in a bit more detail before you try and either create one, or use the ones on there.
http://forums.cisco.com/eforum/servlet/EEM?page=main
Hope this helps
Martin
05-18-2008 08:00 PM
archive
maximum 14
time-period 1440
05-27-2008 08:00 AM
I have sen that if we choose location as local disk, time-period command does not work. only it is with tftp / remote that it works.
