MPLS Circuit. Problem with Routing through the cloud
May 15th, 2008
I just had my first MPLS Circuit turned on. I can ping the other side (router) with no issues. But when I setup routing to go to a server on the other side I cannot get to it.
Here's what I have on my router:
show ip route:
10.0.0.0/8 is variably subnetted, 5 subnets, 2 masks
C 10.10.1.25/32 is directly connected, Serial0/1/0:0
C 10.10.1.24/30 is directly connected, Serial0/1/0:0
S 10.10.1.28/30 [1/0] via 10.10.1.25
S 10.30.10.55/32 [1/0] via 10.10.1.25
C 10.10.1.52/30 is directly connected, FastEthernet0/0
S* 0.0.0.0/0 [1/0] via 10.10.1.53
The 10.10.1.28 is the other side of the MPLS cloudl My side is 10.10.1.26.
I added a route for the a server on the other side of the cloud (10.30.10.55) to go through 10.10.1.25. But when I try to ping from the router to 10.30.10.55 I get the following:
ping 10.30.10.55
Sending 5, 100-byte ICMP Echos to 10.30.10.55, timeout is 2 seconds:
UUUUU
Success rate is 0 percent (0/5)
I know my routes are right, So I'm thinking there is something up with the MPLS Cloud.
Any ideas?
Mike C.
Harold Ritter Thu, 05/15/2008 - 12:41
  • Cisco Employee,
Mike,
It looks like the router on the other side doesn't have a route to this server (10.30.10.55). Is the server directly connected to this router? Who owns this router?
MICHAEL CICCONE Thu, 05/15/2008 - 13:04
Hritter,
No, the server is connected to a switch which is connected to the router. The owner is the same company, But I don't admin the router.
What route should I have in there. Here's what I have in there now:
ip route 0.0.0.0 0.0.0.0 10.30.20.2
ip route 10.10.1.24 255.255.255.252 10.10.1.30
the second route is the route for the MPLS Circuit. Again this is the remote side, not my side.
MIke C.
