IP Phone Messenger
Answered Question
May 15th, 2008
Guys,
I have just setup presnece server (CUPS 6.0.2) and IPPM.
However when I add contacts and choose status as available, All I see is a ? mark by the contact name (Unnown status)
I therefore cant send messages to and between contacts.
Whay can I do
Correct Answer by 8cstephenson about 8 years 8 months ago
Sorry I forgot to add that you should use the IP address of the CUPS box, also don't forget to change the Authentication Parameters (Clusterwide) setting Authentication Module Status to off otherwise CUPC would not register with the server.
Overall Rating: 5 (2 ratings)
8cstephenson Fri, 05/16/2008 - 02:07
We had the same issue, run the CUPS troubleshooter and check under the Proxy Server that Verify SIP Proxy service Proxy Domain service parameter value is valid, if not click on fix and resolve the issue under the service parameters Cisco SIP Proxy -> General Proxy Parameters (Clusterwide) -> Proxy Domain -> Change this from PROXY_DOMAIN_NOT_SET to somthingelse.
Correct Answer
8cstephenson Mon, 05/19/2008 - 06:06
